Home Forums Products Stompboxes Phase issues with Eventide Space during patch changes Reply To: Phase issues with Eventide Space during patch changes
#134826
I have the same problem.  Seems to be worse when switching between two presets that have different output levels set.
For instance, I have one preset with a big hall reverb with a high mix setting and therefore I've increased the output level (3db or so) to compensate for the perceived drop in dry signal.  I have another preset with a small spring reverb, a low mix and therefor a unity output level.  Switching between these two presets, whether via MIDI or footswitches, leads to a couple seconds of wildly varying output volume.  It's a real bummer because you simply cannot smoothly transition between presets.  I really hope it gets fixed.  You end up having to spend a bunch of time managing settings and carefully considering transitions to avoid the wobbly preset changes that I haven't experienced with other units.
