Home › Forums › Products › Stompboxes › Phase issues with Eventide Space during patch changes › Reply To: Phase issues with Eventide Space during patch changes
September 5, 2012 at 12:40 am
#134828
Thank you for your response Dan. I can try setting the preset mixes to 100% wet to test if it will help,, but unfortunately it will make the pedal unusable from a playing standpoint due to having the effect level much to loud on most settings. Do you just want me to test to see if there is still a phasing issue, or was this intended as a temp fix until a bug fix is created? If it is a temp fix, is there a way I can lower the effect volume/level with the wet mix maxed? Thank you again for your help on this,
