Home Forums Products Stompboxes Is this possible via midi with the Timefactor? Reply To: Is this possible via midi with the Timefactor?
#134829
Hi, Thanks so much for your help. Yes, I have discovered most of what
you shared was accurate and working for me. I have also been trying to come up
with an easy midi routing to just use the Adrenalinn and Time Factor pedal, without the
FCB1010 Controller. I did find that it worked well this way when setting the Time Factor PRG XMT
set to ON, to control the Adrenalinn presets, but I was hoping to go
opposite this… having the Adrenalinn presets (#1, #2,#3, etc…) move the Time Factor's
banks 1.1, 1.2, 2.1, 2.2, etc…). Still working on that….and to use Time Factor
TAP because it sets the tempo way sooner than Adrenalinn does.
Thanks again, and when I finalize a great routing, I will share it!
