Home › Forums › Products › Stompboxes › Phase issues with Eventide Space during patch changes › Reply To: Phase issues with Eventide Space during patch changes
September 5, 2012 at 6:40 pm
#134830
Hi ccl117,
I would like to know if this fixes the issue, and I would suggest it as a work around for the time being. You would probably have to use it in conjunction with the output level control for each preset. You can set the output level of a preset by bypassing the preset and holding the active switch. With the active switch held you can change the output level with the encoder. Remember to save the preset afterward.
Dan
