Home Forums Products Rackmount no input meter on H7600 Reply To: no input meter on H7600
#134886
    For the mono send you should use a regular mono guitar-type cable, meaning tip and sleeve, no ring.
    The return is a little harder, as the 7600 has no 1/4" out. Your custom cable should do it, as long as all the XLR pins are connected correclty. It needs to be wired:
    XLR 1
    1 – gnd (Sleeve)
    2 – hot (Tip)
    3 – gnd (Sleeve)
    XLR 2
    1 – gnd (Sleeve)
    2 – hot (Ring)
    3 – gnd (Sleeve)
    You will probably  need to boost the gain on the input and cut it on the output by the same amount.
