Home Forums Products Rackmount no input meter on H7600 Reply To: no input meter on H7600
#134895
    Obviously you could have a hardware fault, but that is unlikely – as you say, they light up at startup.
    Most likely is that you are feeding it such a low level signal that it doesn't show. If this is the case, you will possibly get more noise and distortion than you would like, and level-sensitive stuff like compressors and pitchshifters may not work properly.
