Home › Forums › Products › Stompboxes › FactorLib can’t locate Time Factor – midi? › Reply To: FactorLib can’t locate Time Factor – midi?
        October 9, 2012 at 9:22 am
        #134915
I submitted a reply to this but not seeing it.
Anyways, I got the FactorLib to work… but I can not verify a "saved" SYSTEM Settings file, in the Library. After I select Dump, then System, then hit Send… it sends for about 1 second and I see nothing else happening in the Library, or on the pedal. Should I? Can you tell me in detailed steps how to save my system Settings, and what I should expect to see happen in Factorlib? Thanks.
