Reply To: How to change the timefactor’s bank and the two preset by PEC-2?
Home Forums Products Stompboxes How to change the timefactor’s bank and the two preset by PEC-2? Reply To: How to change the timefactor’s bank and the two preset by PEC-2?
#134945
badmelonfarmer
Glad that was of use.
Right, for bypass you need to assign a CC number to ByPass in the MIDI menu of the TimeFactor and then use your controller to send the MIDI CC number you choose. Say you set it to erm 21..
set the controller to send cc 21 on the midi channel of the TimeFactor.
Some controllers can't sent MIDI CC.
Some controllers call MIDI CC switches IA or Instant Access switches.
If it asks you for a CC value between 0 and 127 then set the "on" to 127 and the "Off" to 0.
So basically you are saying when I press this switch send a value of 127 for MIDI CC 21 on the MIDI channel for the Time factor and this will " engage" the effect, when you press the switch again to turn it off…. It sends MIDI CC 21 with a value of "0" which would bypass the effect.
