Home › Forums › Products › Vsig and Preset Development › Pitch Arepggiator Help › Reply To: Pitch Arepggiator Help
November 12, 2012 at 4:42 pm
#135005
I would suggest that you start with a working looper preset and then add the pitch shifting.
If you want to do it yourself, any mixer module will do. You would put it just before a DELAY and use it to mix the input of the delay with its output, setting the delay time to be the length of the loop. See preset 326_Quad Delays as an example (it's 4 channels, but you'll get the idea).
