Home › Forums › Products › Stompboxes › Flanger sounds from a PF › Reply To: Flanger sounds from a PF
December 5, 2012 at 3:05 pm
#135045
Quote:
Will probably be sufficient for my needs even though its not exactly what is required for the song … one cover version of Dakota.
You might get a little more "depth" out of the preset by changing the Pitch knobs a few cents [Pitch A – A:0.999 / Pitch B – B:1.001]. It still has the problem of no direct control over the sweep rate. I tried different combinations of using the expression pedal as a manual LFO over the delay times themselves. But there's that little crossfade when sweeping delay times that disrupts the clean sweep (an advantage in most situations, though).
Quote:
I also got something useable from my TF using the band delay. Sounds a bit too much like an autowah but its not bad.
Care to post the settings?
