Home Forums Products Stompboxes Factor switch issues Reply To: Factor switch issues
#135119
achaput
    If it's a software glitch, then updating and/or initializing could fix the problem. Initializing will erase your presets so you will want to back them up first using Factorlib, found here.
    To initialize:
    Power up the unit while holding down both the middle footswitch and the encoder button for a few seconds.
    If you still have problems you should email support@eventide.com as the unit may have to get repaired.
