Home Forums Products Stompboxes Can I use the pitchfactor as a detuner? Reply To: Can I use the pitchfactor as a detuner?
#135140
ndeshpande
    If you're referring to the Shimmer algorithm, then not really – the structure of the algorithm doesn't allow for this. If you want to do pitch shifting of any kind, the Pitch Factor is your weapon of choice; Space is geared more toward really expansive reverb algorithms.
    That being said, the detuning and modulation on Space can get pretty crazy, especially at short decay and size times. I've gotten an MBV-type modulation from the wobble in Mangledverb.
