Home Forums Products Stompboxes Eventide announces the H9 Stompbox at NAMM !! Reply To: Eventide announces the H9 Stompbox at NAMM !!
#135185
    styrioci:
    if there is shared AUX SW and EXP PDL input will it be possible to switch between them using AB box?
    There is a single jack – it can be used as expression, or 3*AUX, or a combination of pedal and 1*AUX, depending on how the unit is set up and how the cable is wired.
