Home Forums Products Stompboxes Can the Eventide stompboxes be used as plugins? Reply To: Can the Eventide stompboxes be used as plugins?
#135247
Styrioci
    there is no problem using factor pedals as midi controllers, I've set up Timefactor as controller for Blackhole plugin and it worked great. If you want to use Eventide effects you can use your pedals as outboard FX processors and just run your signal through them.
