Home › Forums › Products › Stompboxes › Can the Eventide stompboxes be used as plugins? › Reply To: Can the Eventide stompboxes be used as plugins?
February 22, 2013 at 6:59 am
#135249
there is catch up feature which will lock preset values until you don't move knob to it's preset value, but in this case presets should be completely locked from being affected by turning knobs. it might be easy to add this feature to system menu, you still should be able to control preset values via expression pedal, hot switch button, tap tempo..
