Reply To: Change TimeFactor parameter values via MIDI
Home Forums Products Stompboxes Change TimeFactor parameter values via MIDI Reply To: Change TimeFactor parameter values via MIDI
#135286
ctc
Thanks again but that is not it. Put simply "Is there any way to send a MIDI command to the TimeFactor to set a parameter's value without using the minimum and maximum trick?"
