Home Forums Products Rackmount Eclipse freezes on power-up Reply To: Eclipse freezes on power-up
#135343
    The Ext and 48k lights will probably be related to a bad digital input. What clock source are you using ?
    Are you using the latest software ? Some of your problems sound like old bugs.
    It is also possible that you have a hardware error – if you think this is the case you should contact support@eventide.com. If your unit is still under warranty you should certainly do this.
