Home Forums Products Stompboxes Can the factors send a MIDI pgm or cc change to a non-eventide device? Reply To: Can the factors send a MIDI pgm or cc change to a non-eventide device?
#135400
I did and that's what prompted the question.  The UM reads:
[XMT MAP] – Create a MIDI Program Change Transmit Map
In Bank Mode, when a Footswitch is used to recall a Preset, a MIDI Program Change message
can be transmitted from the MIDI Out jack or USB to control an external device (e.g. another
Factor series Stompbox, an Eventide Eclipse, an Eventide H000FW, etc.).
…which gives no mention or implication of non-eventide devices being supported.  I was hoping to get a clear answer so I wouldn't have to tear apart my board, reroute cables and change a bunch of settings to find out. I thought since you guys made it, you might know what it can and can't do, What's up with the vague, non-commiting,  wishy washy responses?  This is a programmed electronic device, not some organic thing that may behave differently from one day to the next.  You guys make outstanding products, why is the support so lacking?
