Home › Forums › Products › Stompboxes › H9 Wish List › Reply To: H9 Wish List
August 29, 2013 at 5:04 pm
#135560
Thank you for the reply. I do believe Eventides willingness to listen to the needs of the customer as well as continuing to support and develople their exhisting products (not just resting on your laurels) are key factors that set you apart from other companies in your industry. These are also reasons I no longer use Line 6 products.
Oh, and one more for the wish list:
7) The ability to set the A & B delays as serial or parallel. I may be wrong, but I believe they currently only run parallel. I also own a Strymon Timeline, and this feature alone on makes it a necessity for me as certain rhymic delay patterns only work the way they do in serial.
Thanks again!
