Home Forums Products Stompboxes H9 Wish List Reply To: H9 Wish List
#135565
Normal.dotm
0
0
1
167
956
The Coupers Partnership Ltd
7
1
1174
12.0
Normal
0
false
18 pt
18 pt
0
0
false
false
false
Hi
Just some quick suggestions but nothing revolutionary:
1. First a question, now with the new system with buying new
future effects, I assume that there is no limit on parameters, or is there
still limits, for example could you create an effect with 20 parameters?
The reason I ask is I would like a 15 band graphic EQ or a
parametric EQ plus a delay.
2.Also separate mix controls in the modechoverb algorithm for
each effect.
3. LFO to control ribbon controller, I know there are lots
of modulation options but it would be cool if when you select the parameters
for the ribbon control if then ribbon control would move itself, and set the
speed (not sure if it can do this).
4. More combination effects
Already mentioned:
Pre/post option
Looper
Also, when changing a user preset on the ipod it doesn't
give an option to either overwrite or save under a new name, when I last did it
it just overwrote the existing preset.
I haven’t had my H9 for very long but I’m very impressed with
it and looking forward to the new effects you have planned, and I really like
the iOS integration, makes it very easy to control it and experiment with
sounds.
Cheers
