Reply To: FactorLib can’t locate Time Factor – midi?
Home Forums Products Stompboxes FactorLib can’t locate Time Factor – midi? Reply To: FactorLib can’t locate Time Factor – midi?
#135669
If it does not work with either MIDI or USB I am mystified. Make sure that the USB is disconnected when using DIN MIDI.
If you still have problems, you will need to try another computer, if only temporarily.
