Reply To: H9 MIDI controller DIY
Home Forums Products Stompboxes H9 MIDI controller DIY Reply To: H9 MIDI controller DIY
#135749
Poppy
This is my new custom DIY.
The idea : use a BossFV500H Foot Volume and Expression Volume. Initially, you can't use both because this is the same potentiometer (a double potentiometer) so if the volume is down, the expression is at 0 and if the volume is up, the expression is at max.
My idea : use a footswitch like on a wahwah pedal to switch volume to expression fonction.
I have add a LED when the Expression mode is engaged. The volume is at max (truebypass of course) when the expression is engaged.
[View:http://www.youtube.com/watch?v=GVRah26PBsg&feature=youtu.be:550:0%5D
If you want to see the step by step customisation : http://www.sweepyto.net/Forum-Guitare/Topic-Guitare.aspx?id=45090
I actually enjoy the PitchFlex 🙂
