Home › Forums › Products › Stompboxes › H9 Saving Presets From Pedal to iPad › Reply To: H9 Saving Presets From Pedal to iPad
November 4, 2013 at 6:36 pm
#135774
I see where my issue is. I was not loading the preset from the H9. I was taking it from the Preset List (Which is doable but way more obscure than the right way to do it. From the Preset List, I'd open a preset. Then I'd double tab the name in the left column; this would allow me to rename it. When it renamed it, it'd make a copy (save as vs save). One problem was the numbering was all messed up.).
If I load the preset from the pedal, then I can just rename the preset and it appears with a 'U' next to it. Simple when you know how to do it.
Thanks for your help.
