Home Forums Products Stompboxes Will I be able to buy the Timefactor looper algorithm for the H9? Reply To: Will I be able to buy the Timefactor looper algorithm for the H9?
#135784
coirbidh_99
    So three possible behaviors for the Record function:
    -Stomp on, stomp off – the phrase looper standard
    -Quantized record: stomp to record for one subdivision at the specified tempo (this mode requires a three-button setup, so that the Play button works as tap tempo when there's no loop in memory)
    -Momentary record: record the initial loop only while Record is depressed
    Works for me!
