Home Forums Products Stompboxes Pitchfactor H910 emulation Reply To: Pitchfactor H910 emulation
#135839
    Quote:
    set it to completely dry…. perfect sound
    now set it to 0 delay, 0 feedback, 1.00 pitch and totally wet…. can u hear the lofi sound?
    Yes.  That's the H910 'character' you're hearing.  It was an amazing piece of hardware for its time (mid-70's).  Analog delay chips were noise buckets back then, and one solution was to lower the bandwidth.  Longer delay times meant that the "low pass filtering" cutoff frequency was reduced.  Usually, you'd get a range of delay times; each with its own bandwidth. I believe that the H910 was a 16-bit/ 15kHz machine overall.
    Part of the lo-fi charm of the H910 and H949 algorithms is the varying degree of glitching, deglitching, and warblyness found in each variation,  In your experiment –  if you move the Depth / Key knob to MODERN at 1.000 –  you'll hear clean, subtle unison doubling.  That sounds like what you're looking for.
    But don't overlook the unique, useful sounds in the H900 series.  You can really start to hear the differences between the 3 hardware emulations and digitally-clean when there is some pitch shifting involved.  You can set up up a simple preset, and sweep the Depth / Key knob to compare one with the next:
    TidesOfHistory
    Mix = WET:50
    Pitch Mix = A10+B10
    Pitch A = A: 1.498
    Pitch B = B: 2.000
    Delay A = 0 ms.
    Delay B = 0 ms.
    (encoder) = 910/949/ TMP OFF
    Depth / Key = H910 / H949-1 / H949-2 / MODERN
    Speed / Scale = CHROMTC
    Xnob = FBK-A:  0
    Ynob = FBK-B:  0
