Home › Forums › Products › Stompboxes › H9 button re-assign › Reply To: H9 button re-assign
December 4, 2013 at 11:12 pm
#135863
That kinda stinks because if you have an external switch in which you have the increments and decrements, you have to go between pedals to activate the chosen preset. Would be much better if you could program it like this so you wouldn't have to go back and forth between the H9 and the external switch when changing presets.
Ideally if the external switch would be unplugged, the H9 would go back to its default setting (left bypass – right increment)
Cheers
