Home Forums Products Stompboxes H910 chromatic scale display Reply To: H910 chromatic scale display
#136191
    Quote:
    Incidentally I'm looking to reproduce the drum sound used by Tony Visconti on David Bowie's "Low" album … if I can do this within the Pitchfactor, I'll be able to recreate the sound I want live.
    The guy from Eventide answering all of your questions above is certainly more qualified that I am here.  He invented it.  But this should get you started:
    BreakingGlass
    Mix = WET:50
    Pitch Mix = A10+B10
    Pitch A = A: 0.944
    Pitch B = B: 0.944
    Delay A = 30 ms.
    Delay B = 30 ms.
    (encoder) = 910/949/ TMP OFF
    Depth / Key = H910
    Speed / Scale = CHROMTC
    Xnob = FBK-A:  80
    Ynob = FBK-B:  80
    This uses both pitch shifters set up identically; you may only need one.  Adjust the Pitch or Delay knob slightly in one of the pitch shifters to get a thicker sound.  General rule of thumb for this kind of effect:  Longer delay time – less feedback level.
    If you want to remain 'authentic', keep the Depth/Key knob on H910, and have your Delay set close to an increment of 7.5, 15, 30, and 60 ms. [the original switch selections – up to 112.5 ms.].  Of course, a setting of MODERN with any number of milliseconds is fair game, and noticeably cleaner.
    The PitchFactor makes it easy to switch between downshifting and upwards pitch shifts with an aux switch, expression pedal, or over MIDI.  Move the Mix knob higher for more effect with less of the original signal.
