Home › Forums › Products › Stompboxes › Space is changing parameters alone ! › Reply To: Space is changing parameters alone !
February 15, 2014 at 9:02 am
#136197
Yes, I know that current doesn't matter but only if it's higher. I verified the voltage and the current of eeach power supply. 9V 500mA for Space and 9V 1200 mA for Time or ModFactor. So it must be ok with all these power supplies. Actually, I use the PowerFactor and it works with 12V 400mA. It was ok for a moment.Then it began to change all the parameters like shown in the video.
They said it was an hardware problem. It took 6 months to got it back. Since, I only used it 3 times and not for a long time use. I hope it will be ok …
I really wish you to find the problem !
Look after yourself, take your medicine 😉
