Home › Forums › Products › Stompboxes › H9 Wish List › Reply To: H9 Wish List
Eventide – Can we expect spillover on H9 soon? My Timefactor has it so don't understand why this wasn't included in the first release?
When using my timefactor in a midi setup (audio loop on or off plus timefactor output into line mixer as parallel loop killdry enabled) i toggle between 2 different audio loop presets (rhythm TF loop off & lead with TF loop on) both of which are selecting the same TF delay patch – when switching between lead and dry rhythm the delay trails off smoothly and sounds great. If I try and emulate this with the H9 it doesn't sound smooth at all, not sure what the difference is here but could you advise what the issue is here and if I can fix it with the current firmware? If not can I expect a fix in the next firmware update? Hope this makes sense?
