Home › Forums › Products › Stompboxes › H9 App Change Control Process › Reply To: H9 App Change Control Process
March 15, 2014 at 3:09 am
#136283
Priestunes:
if I make any changes from the preset list and then publish to the pedal, that will be sufficient?
Yes, that will work.
Priestunes:
If this is the case, then all is well, and I only wish to delete duplicated preset names and their corresponding presents at some point. Will this ever be possible?
You can do this now. If you select a user preset in the Presets screen and click on the More button, there's a "Delete preset" function, which you can use to delete user presets.
