Home Forums Products Stompboxes Sending CC messages using h9 aux switch Reply To: Sending CC messages using h9 aux switch
#136298
siggy76
    I've swapped how the units are connected and now it works. Now the problem is that the h9 doesn't merge the Cc messages from other units when the output is set to XMIT but only in thru mode…but in this mode no Cc from the H9 are transimetted.
