Home Forums Products Stompboxes H9 Active/mute Reply To: H9 Active/mute
#136309
RavinDave
    I'll add a bit more: Hooked up my new H9 yesterday, set up the bluetooth and was thrilled with discovery, to the point of sore fingers. Today I cranked it up and when I pressed the Bypass (left) button my thru signal had disappeared. Yikes! I had made no changes and even tried my best to hold my jaw in the same position as the night before. No luck.
    Per the PEDAL SETTINGS the H9 should be pushing the dry signal thru (to my TimeFactor). No luck. I can clearly see the H9 is receiving the signal in bypass mode but it’s not passing thru. Yikes!
    My apologies if this has been covered in this forum but the search function here leaves a lot to be desired. Any input would be greatly appreciated.
    RD
