Home Forums Products Stompboxes H9 Active/mute Reply To: H9 Active/mute
#136310
gkellum
    So, what happens when you hit bypass?  It mutes the output?  What Bypass Mode is set?  If you click on the Pedal button in the bottom right hand corner of H9 Control and go to Bypass Mode, what is it set to there?  I'd try the different options there and see if one of those fixes your problem.
