Home › Forums › Products › Stompboxes › H9 midi cc problems › Reply To: H9 midi cc problems
March 21, 2014 at 7:17 pm
#136313
No magic, I'm afraid. Assuming the settings are good, it could be a cable problem, or less likely, a hardware fault.
You should set channel to OMNI and use the MIDI "Learn" function to have the best chance of it working.
If you are convinced that everything at your end is OK, contact support@eventide.com.
