Home › Forums › Products › Stompboxes › DIY Aux pedal ques › Reply To: DIY Aux pedal ques
#136481
rabiddiabetic13
    the aux switch you build will need a TRS cable from aux pedal to Timefactor.
    Switch 1 Tip+Sleeve,
    Switch 2 Ring+Sleeve
    Switch 3 Tip+Ring+Sleeve
    You could get a TRS Y cable  but it would activate the aux programming on both pedals at the same time.  Might not be a problem if you don't have both pedals active at the same time.  Although you would be missing a lot of fun and great sounds not running them both at the same time some of the time.
    TRS Y cable link
    http://www.sweetwater.com/store/detail/CYS103/
