Home › Forums › Products › Stompboxes › play or bank mode with midi foot controller ? › Reply To: play or bank mode with midi foot controller ?
May 1, 2014 at 6:28 pm
#136559
You should probably find a knowledgeable friend or local tech to help ..
In the meantime, if you put the MF first, you must set it to THRU to pass incoming stuff on. Then pick different MIDI channels for the MF and the TC so they will know what controls are for them.
