play or bank mode with midi foot controller ?
Home › Forums › Products › Stompboxes › play or bank mode with midi foot controller ?
Viewing 7 reply threads
    • #111583
      Hi i'm sorry but i'm new to midi world , i'd like to ask you one thing, i just bought the midibuddy foot control to use with my modfactor,  should set my eventide in play or bank mode to use it with a midi controller ? or it's the same ? Thanks a lot.?
    • #125832
        It's the same either way.
      • #125834
        Thanks a lot, is it correct if  i set  omni  ?
        It's not that easy  the first time
      • #125835
        Thanks a lot, is it correct if i set it to Omni
        the midi language  it's not that easy the first time
      • #136557
          If the only thing you are controlling is the MF, omni is fine. If you add other things, you'll need the different channel numbers to keep them separate.
        • #136558
          i'm going to use it with the tc electronic nova system, only the modfactor and the nova, any idea ? the mod it's the first in chain
          please help me because it's hard
          Thanks again
        • #136559
            You should probably find a knowledgeable friend or local tech to help ..
            In the meantime, if you put the MF first, you must set it to THRU to pass incoming stuff on. Then pick different MIDI channels for the MF and the TC so they will know what controls are for them.
          • #136560
            Thanks a lot again, i ' ll do that
