Home Forums Products Stompboxes H9 midi problems Reply To: H9 midi problems
#136576
    Quote:
    MIDI clock illustrates the problem – if it was getting two different clocks, it is not at all clear what it should do.
    I'm seeing what the issue was here – at least with the PitchFactor under H9 Control.  With USB connected – and with or without MIDI DIN input connected – I was getting the Clk In -> On flashing warning.  A sure sign that the PitchFactor was not receiving MIDI Clock from any source.
    Somewhat counterintuitively, System Settings -> MIDI -> Clk In -> OFF (or No in the H9 Control) establishes bi-directional (MIDI Clock) communication between the PF and H9 Control.  Under that condition, I've found that the DIN input can stay connected – even with an incoming MIDI Clock – without affecting the link.
    That's going to help with compiling a large number of presets that may or may not be sync'ed to tempo.
