Home Forums Products Stompboxes Anyone else screaming for a mix on Modfactor Reply To: Anyone else screaming for a mix on Modfactor
#136642
Agreed St Bede, but trying to pass the intensity as a wet/dry is a little off, the intensity does not mix the guitar signalwith the modulation, but instead replaces it as you dial up.  To blend and to replace is a different thing.
I appreciate the help guys, in all I just wanted to be able to use the pedal, can't to suit everyone.
