Home › Forums › Products › Stompboxes › H9 output level control › Reply To: H9 output level control
#136714
Is this issue in progress or fixed?
For me this is the dealbreaker for making h9 as my gigging pedal.
I use mostly echoes/delay with expression pedal.
When I need a bit or a bit more wet, more delays, the whole sound gets low and
totally loose its place in the band. It ends up quite useless then:(
This problem is quite extreme with the tape echo, when i go from 20% to say 50% wet,
the main output/loudness/prescence is getting very much weaker.
(Even when the tone on the echo is kept bright)
So,- please make the output volume a part of the parameters which can be
adjusted with the expression pedal. Or at least make the tape echo's Echo Volume be accesible in the same manner.
