Reply To: Midi output with a controller
Home Forums Products Stompboxes Midi output with a controller Reply To: Midi output with a controller
#136852
basslayer
So the merge did not work at all. The expression won't transmit, regardless of what the midi outputs are set to. Are there any future firmware plans to address this issue? I know I am not the only user that also uses control pedals like the midi moose, and not being able to transmit expression while using and outside controller is extremely limiting.
