Home › Forums › Products › Stompboxes › Expression pedal & aux switch used together › Reply To: Expression pedal & aux switch used together
June 27, 2014 at 10:26 pm
#136891
What's the difference between the EB volume pedal and the Moog exp pedal?
Is the EB mono and the Moog stereo?
I noticed that a Boss EV-5 doesn't work correctly via a Y-cable. Did the Moog exp pedal travel from the heel position value 0 to 100 halfway and then back from 100 to about 10? The value 10 when the pedal was in the toe position? So 0 -> 100 – 100 -> 10 all in one travel from the heel to the toe position.
