Home › Forums › Products › Stompboxes › H9 Y-Cable to use both an Aux switch and Expression pedal › Reply To: H9 Y-Cable to use both an Aux switch and Expression pedal
June 27, 2014 at 10:46 pm
#136892
harmamusic:
The expression pedal goes from 0 to 100
This may be your pedal – if it is a little weak, you can hit it hard during calibration, which sets a limit. Then, later, unless you hit it equally hard, you may not be able to hit the same limit. Try calibrating very gently, and then turning calibration off.
harmamusic:
When set to EXP it ignores the aux switch
It will ignore the TIP of the switch, because you have told it you are using this for pedal.
harmamusic:
H9 doesn't seem to send out it's clock
Make sure that MIDI.CLK.OUT is ON.
The cable should be as I described earlier.
