Reply To: H9 Y-Cable to use both an Aux switch and Expression pedal
Home Forums Products Stompboxes H9 Y-Cable to use both an Aux switch and Expression pedal Reply To: H9 Y-Cable to use both an Aux switch and Expression pedal
#136894
gkellum
harmamusic:
When set to EXP it ignores the aux switch
If he's trying to connect an AUX switch and expression pedal simultaneously with a Y cable, shouldn't this be set to Both instead of EXP?
