Home › Forums › Products › Stompboxes › H9 Y-Cable to use both an Aux switch and Expression pedal › Reply To: H9 Y-Cable to use both an Aux switch and Expression pedal
June 27, 2014 at 11:10 pm
#136895
Just tried it again – connecting one of my EV-5 pedals via a stereo cable into the H9, set EXPTIP to EXP
The value I see on the H9 pedal from heel to toe is 0 to 90 with minimum volume of the EV-5 set to off.
