Home › Forums › Products › Stompboxes › H9 Y-Cable to use both an Aux switch and Expression pedal › Reply To: H9 Y-Cable to use both an Aux switch and Expression pedal
June 28, 2014 at 6:17 pm
#136900
It helps if you could let me know which aux switch(es) and expression pedal(s) you've tested this with? I can check how these are wired and conclude what changes I need to make.
Thanks in advance!
