Home › Forums › Products › Stompboxes › Expression pedal & aux switch used together › Reply To: Expression pedal & aux switch used together
June 28, 2014 at 10:01 pm
#136908
I just read somewhere that there's a difference between momentary switches.
Normally closed versus normally open. It mentioned that Eventide uses the normally closed where I might have a normally open switch? Does that shead some light on the discussion?
