Home › Forums › Products › Plug-Ins › Ultrachannel – VST Plugin Scan fails to find Ultrachannel › Reply To: Ultrachannel – VST Plugin Scan fails to find Ultrachannel
#136962
DGillespie
    Hi Markus,
    You might want to manually uninstall UltraChannel and re-install it, double checking that the 32 and 64 bit versions of the plug-in are pointed at the correct folders.  It sounds to me like you might have ended up with the 32 bit plug-in in the 64 bit folder.  Unfortunately there is no easy way in Windows to differentiate the two.
    Thanks,
    Dan
