Reply To: MacBook Pro USB does not recognize H9
Home Forums Products Stompboxes MacBook Pro USB does not recognize H9 Reply To: MacBook Pro USB does not recognize H9
#137078
I was unclear – when you connect by USB, the H9 will appear as a MIDI device. The same applies whn you connect by actual DIN5 MIDI.
It might be helpful if you try both and tell us what you see under CoreMIDI.
