Home Forums Products Stompboxes H9 Program Change Messages Reply To: H9 Program Change Messages
#137101
Epsilide
    I've checked the midi settings hundreds of times, including XMT.PGM but this is all right.
    Program Change in works but the problem is in the out.
    iI'll try a new cable but I think that is not the problem if we look at the test results. Maybe could be a bad connection THAT cable on THAT device, because other devices trasmit PC with the same cable.
    I'm desperate.
